Introduction: Soft & Neutral Fall Makeup Look
About: i have a youtube channel and love to share my ideas :)
This look is perfect for everyday and every night you can make it as glam or natural as you like. I hope you like this look and maybe learn something.
Step 1:
Using your foundation you are going to want to apply this to your face and neck making sure there are no harsh lines.
Step 2:
Using a concealer you are going to want to highlight your face. So apply this to your under eye, chin, forehead and nose. Then go in with a beauty blender and blend this out.
Step 3:
Then using a bronzer or a contour palette you are going to want to shape/contour your face. I then go back in with my foundation brush to make sure there is no harsh lines.
Step 4:
Using whatever brow products you use you are going to want to fill in your brows.
Step 5:
Using a light beige colour you are going to want to blend this into the crease of your eye as a transition colour.
Step 6:
Then using a soft glitter pink colour you are going to want to apply this to the lid of your eye. I did apply this with a wet brush.
Step 7:
Using a dark brown you are going to want to apply this to the outer corner of your eye and then blend this out so its not so harsh.
Step 8:
Using a black eye shadow you are going to want to draw a V in the outer corner of your eye and then blend this out so it doesn't look so harsh.
Step 9:
Using a very bright blue you are going to want to apply this to the inner corner of your eye.
Step 10:
Using the dark brown that you used on your eyes you are going to want to blend this on the lower lash.
Step 11:
Using your eyeliner you are going to want to apply a winged look and also into the waterline.
Step 12:
Then apply your mascara to your top and lower lashes.
Step 13:
Then using a soft pink you are going to want to apply this to the apples of your cheeks
Step 14:
Finally you are going to want to apply a nude lipstick.
