Introduction: Social Distancing Alarm
About: Hello everyone ! I am Archit Singh and I study in class 7. Making innovative things is like my hobby . I am 12 now. When I was at 7 then I started making small projects with dc motor and batteries but when I g…
Hello Everyone as we all know that covid-19 is all over the world . So I have taken a small initiative to stop covid-19 by making this alarm. Actually I have coded that the ultrasonic sensor will measure that the distance is less than 2 gaz or not. If it is less than 2 gaz then the buzzer starts beeping and as the person gets closer and closer the buzzer should beep faster and faster. It took me 2 months to make this model .Today in the hour of Trouble this alarm is no less than a boon. I humbly request you all to share this project as much as possible so that our workers, employers and others can be safe from coronavirus till the vaccine arrives. I hope you will share this alarm so that it can be used socially.
Arduino Uno, Ultrasonic Sensor, Buzzer, Battery, Body(In which alarm can be made), Decoration Tape
Step 1: Join All the Wires
The Circuit Diagram is Given above. Make all the connections as Directed
Step 2: Source Code of the Project
You have to use arduino ide app to insert the code in arduino. Download the app from this link - https://www.arduino.cc/en/software
Source code -
int trigpin = 4;
int echopin = 5;
int buzzer= 3;
int timer;
long duration;
int distance;
void setup()
pinMode(3,OUTPUT);
pinMode(trigpin, OUTPUT);
pinMode(echopin, INPUT);
void loop()
digitalWrite(trigpin, LOW);
delayMicroseconds(2);
digitalWrite(trigpin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echopin, HIGH);
distance = duration*0.034/2;
timer = distance * 10;
Serial.print("Distance: ");
Serial.println(distance);
if(distance<182) {
digitalWrite(3, HIGH);
delay(50);
digitalWrite(3, LOW);
delay(timer);
else
