Introduction: Space Saving Clamp Storage Rack
Hey, guys! I just finished up a parallel clamp rack for the shop and I love this thing! I used a stacked approach vs. the typical side by side approach and it offers some massive space savings (I got the idea from Dyami from Penultimate Woodshop).
The rack is 38-3/4” wide and will fit 24 parallel clamps stacked 6 deep in 4 bays. It will also hold 12 bar clamps stacked 6 deep in 2 bays. If you used the side by side method you’d need 48” just for the parallels alone! I also made a top to it so I can use the upper shelf for some added storage.
Materials
- 3/4" Plywood
Tools
- Tablesaw
- Cordless drill
- t-bevel
- Pocket hole jig
Read the instructable here and you can also get a download of the plans with measured drawings over at my website:
http://fixthisbuildthat.com/woodworking-parallel-clamp-rack-storage-plans/
Step 1: Cut the Sides for the Clamp Rack
Cut two sides out of 3/4" plywood. Draw a diagonal line down one side. Connect these lines and use a t-bevel to translate the angle to your tablesaw miter gauge. You could also cut this line with a circular saw.
Step 2: Cut and Assemble Clamp Support Pieces
Cut 5 triangles and 5 support arms.
Drill pocket holes in the side of the triangle and on one of the short sides of the support arms. These will be used to attach the supports to the back later.
Center, glue, and screw the support arms to the triangles on the long side of the triangles.
Step 3: Attach Sides and Side Supports to the Back
Cut a left side support and a cleat. Join the two together to form an L-bracket and attach to the left side piece,
Repeat this for the right side with a support and cleat. Attach down from the top of the right side piece.
Cut a back piece and secure the side pieces to the back with 1-5/8" wood screws.
Step 4: Add Top and Attach Interior Support Arms
Cut a top and secure it to the back and sides with 1-5/8" screws.
Attach the interiors support arm assemblies made in step 2 to the back with 1-1/4" pocket screws. The assemblies should be inline with the side supports. Each assembly should be spaced away from the other to provide room for the clamps.
Step 5: Mount the Clamp Rack and Add Clamps
Mount the clamp rack to your wall. Make sure you hit at least 3 studs and use 3" wood screws. I suggest 3 screws per stud for a total of 9 screws.
Add in all your clamps and be amazed at how organized your shop just became!
