Introduction: Spaghetti and Meatballs
To make spaghetti and meatballs these are the ingredients that you will need: black pepper, salt, granulated onion, granulated garlic, browning, ground beef, noodles, marinara sauce.
Step 1: Lets Begin
First things first, you will need to thaw out your ground beef. When it is done melting but it into a bowl. Put granulated onion powder, black pepper, granulated garlic, and browning. Now mix it all together
Step 2: Form Your Meatballs
Once you have everything mixed together, begin to from your meatballs. You can make them as small or as big as you will like.
Step 3: Start on the Noodles
Add some water into a pot. Put salt into so that it boils faster. Put olive oil into the salt water so that the noodles won’t stick together
Step 4: Get Your Pan Ready for the Meatballs
Put olive oil onto the pan. When it starts to get hot put the meatballs in
Step 5: Flip the Meatballs
While the meatballs are in the pan continuously flip the meatballs so that it can cook all over. Put a cover over so that the steam can stay in the pan and the meatballs can cook faster.
Step 6: Back to the Noodles
When the salt and oil water mixture begins to bubble put your spaghetti in. Make sure to mix at least every 5 minutes, this is to ensure that the noodles don’t stick to each other.
Step 7: Add Your Sauce
Put some marinara sauce onto your meatballs. You can also add some water with it. Add some extra black pepper if needed and mix.
Step 8: Check on Your Noodles
When you think it may be time to strain your noodles, be sure to take a few noodles out to make sure it taste good. I like mine soft so i kept it in for a little longer
Step 9: Don’t Forget About Your Meatballs
Although you are working with the noodles, be sure to be attention to your meatballs. Make sure you are still flipping your meatballs.
Step 10: Strain Your Noodles
When the noodles taste the way that you like them. Get so gloves and strain your noodles. When you are done straining them put them back into the pot.
Step 11: Check Your Meatballs
When you think your meatballs might be ready take a piece and check the pan inside.
Step 12: Your All Done
When your meatballs and your noodles are least put them all together an there you have it, delicious spaghetti and meatballs!!
