Introduction: Sparkleball Mini
Mini-sparkleball is the little light ball everybody loves. Cuter version of the big sparkleball
You'll need:
1. 50 condiment cups - 1 oz size with slanted sides - like the little cups that ketchup comes in at hamburger places.
2. soldering iron, stapler, or holepuncher
3. string of mini-lights (50-70 count)
Step 1: The Right Cups
Start with the right cups. Use 1 oz condiment cups, like the little cuties that you pump ketchup into at a hamburger place. They should have slanted sides. Here you see one next to a 9 oz "Solo" tumbler (the cup for a basic sparkleball.)
Step 2: Cup Bottoms
(photos show 9 oz cups but you're working with the little mini cups) With a hot soldering iron or woodburning tool, poke a hole in the bottom of all 50 cups.
Step 3: Layer 1
Arrange 12 mini-cups in a circle. Join them to each other at cup bottoms, melting a joint between them with the soldering iron. Or staple. Or hole puncher and zipties. This ring is the first layer.
Step 4: Layer 2
Add 9 cups around the top of the first layer, joining them to the cups they sit on top of. There will be gaps between the cups in this layer; space them as evenly as you can.
Step 5: Layer 3 AND Lights
Fit 4 mini-cups into the gap left in the top of the ball half. Flip it over so you're working from the inside. Start threading lights by inserting 1 (or more depending on total number) light into a cup. Always test the lights before you begin and start inserting with the lights closest to the pronged plug end. (see photo)
Or if you're lazy just stuff the lights in the center.
Step 6: 2nd Half
Set aside the ball half full of lights. Build second ball half as in steps 1-4. When you insert lights in the second half, start working from the opposite end of the lights (plug end.)
Step 7: FINISH
Fit the two halves together, making sure the plug hangs out between them (and the connector plug too if you plan to link more than one together). Join the halves by melting joints wherever cup rims touch. Hold the halves tightly together as you work, but be very careful not to melt wires.
Make a hanger anyway you choose. First decide where you want the cord to come out, top or bottom. Then burn a hole between two cups. Use an "s" hook -- clear fishing line -- zip ties -- wire -- or a coat hanger or whatever you want to make a hanger for the sparkleball.
Step 8: Plug in and Enjoy!
Cute as a button! Look for odd mini-lights on sale after Christmas. They work great! These are "bubble" lights, the lights in Monica's lighted mini-ball are blue and white prism lights.
To see more sparkleball ideas, including a mini made of shot glasses, and sparkleball photos check out sparkleball.com.
