Introduction: Spartan Mini Skate Board
In this tutorial I will show you how did I made my Spartan Miniboard with wood.
Step 1: Step 1: Create Your Design
Creating the design by making a few sketches is the most important part, because it will define the main concept and the final looking of your product.
Step 2: Step 3: Cut the Wood
In this part, you already have to know the exact size of your board to cut the table
Step 3: Step 3: Add Some Details
Here, I add the details to the board. There are so many tools you can use to make this, it al depends on the design and complexity.
Step 4: Step 4: Blend the Tail
To blend the tail, the wood has to be under the water for 24 hours.
After that, blend the wood with clamps and let it dry for 24 hors.
Step 5: Step 5: Cover and Protect
Cover the wood with varnish in order to protect it from dust and moisture. Iven it make it look shiney!
Step 6: Step 6: Add the Wheels
This is the easiest part, just set the trucks on the rear part of the board, with a pen, pencil or marker draw point or circles where the screws has to be. then make 8 holes, put the trucks again but fix them with the screws.
