Introduction: Spinning Plant Pot
This is a plant pot that spins, so you can the spin plant can and when you spin it you can get a full circle of water around the plant. Also its nice for a plant pot to spin and get MAXIMUM SUN so i can grow big and strong and it is eight inches.
A ball barring (get the ball barring after you printed out the pot to see how big it need to be.)
any colored filament
3D printer
Step 1: Put the Plant Pot Together
The plant pot is three pieces and put together as one. So its easy to be put together
Step 2: Print Out the Pot
finally you need to print out the pot so you can use it as a plant pot. I recommend use melt away support instead of break away.
Step 3: Put the Pot Onto the Ball Bearing Ring
Once you have printed out the pot. Then you will place the pot on top of the ball bearing ring, the pot has a small stand to put through the center of the ring, so it wont fall off easily. Also get the ball barring after you print out the pot, so it fits.
Step 4: Put Soil and a Plant in the Pot
once you put the pot and the ball bearing ring together. You can put soil and a plant in the pot. Finally you can slowly spin it and water it.
