Introduction: Spooky Blend
In this project you can learn how to make a basic pumpkin rig in blender .
its pretty easy if you follow along ,
feel free to comment and ask questions :)
stuff you need :
Blender 3d software
patience
thats it :))
Step 1: Open Blender and Load Up General File
pretty straight forward ..
Step 2: Making the Pumpkin Model
after opening the file ,
add in a circle with 10 vertices .
shortcut - shift+a
next ,
extrude the circle and give it a rough pumpkin shape
you can fill in the small circle using 'f' as shown in the pictures above
Step 3: Shaping the Pumpkin
now,
select the pumpkin and add a subdivision surface modifier and apply it
also ,
shade the object smooth using right click
next,
select lines in the model to make as grooves in the pumpkin and add a small bevel to those using 'ctrl+b' and then resize them using 's' key to make the grooves.
Step 4: Making the Stem
add a cube and add subdivision surface modifier then extrude and shape it to look like a stem .
Step 5: Final Step Rendering
now just colour the model using material tab and render
I renderer in an old model i made in blender .
