Introduction: Spring Green Space Easy Crochet Table Runner
About: Hello all!!!! A warm Welcome and It's a pleasure to have you here. Art and Craft is my passion .I love experimenting new and creative ideas.
A handmade Crochet Table Runner adds a special touch of personality and your own creativity to your dining space. Crochet table runners are one of the best ways to spruce up your space. A crocheted table runner is both functional and practical. A table runner helps protect the table surfaces and also adds elegance to it.
Today am sharing the pattern for Spring Green Space Easy Crochet Table Runner. Its a easy to follow pattern made with simple crochet stitches. You can easily adjust the size of the runner so you can adjust it any length you need in order to fit your space. You can even use different colors to match different seasons or occasions.
Base - 10 inches - Customizable to any size
Length - Customizable to any size
Visit https://rajiscrafthobby.blogspot.com/2024/05/spring-green-space-easy-crochet-table.html
4 Ply Cotton Knitting Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 40.
This measures around 10 inches.
You can adjust the size by altering these stitches according to your requirement.
Start with any Multiple of 10.
Step 3:
Round 2:-
1 Double Crochet in the 5th Chain from the hook.
1 Double Crochet each in the remaining stitches.
Once you reach end, Chain 1 and turn you work.
Step 4:
Round 3:-
1 Single Crochet in the 1st stitch.
Chain 3.
Skip 3 Stitches.
Repeat(1SC,Ch3,Sk3)
1 Single Crochet in the last stitch.
Once you reach end, Chain 2 and use the Straight Edge Turning Chain to make the turning chain.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
  • Insert the hook into the 1st chain from the bottom.
  • Yarn over and pull up a loop. You should have 2 loops on the hook.
  • Turn your project and insert the hook into the first stitch.
  • Yarn over and pull up a loop. You will have 3 loops on the hook.
  • Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
  • Lastly, yarn over and pull through 2 loops.
  • This will make one Double Crochet.
Step 5:
Round 4:-
**This round we will be making the stitches only in the Single Crochet from previous round.
1 Double Crochet is already made while making the turning chain.
3 Double Crochet in the same stitch(that's total 4 Double Crochets)
In the next Single Crochet stitch make - (1 Single Crochet, Chain 3,3 Double Crochets)- all in the same stitch.
Repeat((1SC,Ch3,3DC)-all in the same stitch) in each of the Single Crochets.
Once you reach the end ,Chain 2 and use the Straight Edge Turning chain to make the turning chain.
Step 6:
Round 5:-
**This round we will be making the stitches only in the Chain 3 space from previous round.
(1 Double Crochet is already made while making the turning chain)
Chain 3.
1 Single Crochet in the next Chain 3 Space.
Chain 3
Repeat(1SC(into the Ch3 Sp),Ch3)
Step 7:
Round 6:-
Step 8:
Round 7:-
Chain 3.
Chain 3
Step 9:
Round 8:-
3 Double Crochets into the Chain 3 space.
1 Double Crochet into the next Single Crochet.
Repeat(3DC(into Ch3 Sp),1DC(on the SC))
Once you reach the end ,Chain 1 and turn your work.
Step 10:
Round 9 Onwards:-
Keep Repeating the rounds from Round 3 to Round 8 untill the size needed and weave off.
