Introduction: Star and Feather Wall Decor
Want a fun, upbeat wall decoration? This piece of art is calling your name and it only cost 10 dollars! This step by step process should only take you about 30-45 minutes.
Six pieces of paper, a yard of yarn or string, and approximately 8 feathers, scissors, tape, stapler, ruler, and a hole puncher
Step 1: First, You're Going to Want to Cut of 2.5 Inches From All of the Pieces of Paper to Form a Square.
Make sure you cut off the longer side in order to form a square.
Step 2: Fold the Squares Into Triangles.
For each square piece of paper, fold them into triangles.
Step 3: Fold Into Another Triangle.
Next, you want to fold the triangle into another triangle.
Step 4: Draw 4 Lines.
Draw 4 lines horizontally from the closed edge of the triangle.
Step 5: Cut Along the Lines.
Cut along the lines and then open up the triangles to make sure there are no more folds.
Step 6: Tape the Center Sections Together.
Step 7: Flip and Tape.
Flip to the other side and tape the next two pieces together.
Step 8: Continue.
Continue this process by flipping the paper each time you tape a new section. Finish the 5 other pieces of paper using these same steps.
Step 9: Tape 3 Together.
Tape 3 pieces together at the corners. Do the same with the three that are leftover.
Step 10: Tape the Neighboring Pieces.
Tape the neighboring pieces together in order to make it stable.
Step 11: Hole Punch.
Hole punch one hole in four of the corners. Make sure that the four corners are in a row.
Step 12: Cut String.
Cut 4 strings that are 12 inches long.
Step 13: Add Feathers to String.
Add a little feather, then a big feather, and then another little feather to the end of each string.
Step 14: Tie Knot.
Tie a knot securing the feathers at the end of the string.
Step 15: Finish
Use the hole punch to tie the opposite end of the string to the star, making sure the feathers will dangle towards the floor.
