Storm-proof Messenger Bag
Intro: Storm-proof Messenger Bag
The purpose of this project is to build a super strenght, waterproof messenger bag to keep your gizmo away from dangers when biking.
STEP 1: Materials
- sandbag
- a broken dog chain
- 2 pieces of velcro
- tape
- used belt
STEP 2: Prepare the Sandbag
- clean the inside of the bag using water (a lot of remaining sand will be inside)
- make sure that the bag is dry (inside and outside)
- choose the worst side of the bag (the dirty one)
- cut out half plastic layer (see the first image).
- keep the cut part for next steps.
STEP 3: Add Velcro to Edges
- Add velcro to edges.
- Before attaching to the sandbag make sure that when the bag is full of things, the two sides of the velcro will match.
NOTES: I used self-adhesive velcro. If the adhesive is not so strong you can use some staples. If you use staples, keep in mind to waterproof the staples putting tape over them.
STEP 4: Add the Chain to the Bag
- put the chain on the center of the bag (where the bag will fold). Check that the chain is longer than the size of the bag (first photo)
- cut out from the remaining piece of plastic a rectangle wider three time than the chain anl longer as the bag
- put the plastic rectangle over the chain (third photo)
- attach the plastic rectangle to the bag using tape.
- fix all the holes on the bag using the same tape (last photo)
STEP 5: Add the Belt to the Bag
- attach the belt to the chain on both sides
- close the ends of the belt with a bolted joint
- try to wear the bag (empty and full) and adjust the lenght of the belt until you feel confortable
STEP 6: Decorate
- if you don't like in plain color you can decorate your bag
- i used spray colors and some DIY paper stencil. Spray paint works very well on this plastic.
12 Comments
Whales 14 years ago
domestic_engineer 15 years ago
i really like the belt for the strap. genius.
.happy.hippie. 15 years ago
an old 40 pound dog food bag works too. they're a little easier to find
Whales 14 years ago
KMOM14 15 years ago
KMOM14 15 years ago
sheen12 15 years ago
LawnBoy1991 15 years ago
derte84 15 years ago
Wasagi 15 years ago
Again, Great Job!
emdarcher 15 years ago
definitly a 5 star rating on this one!
