Introduction: Stuffed Animal Purse
Materials
Stuffed animal
Chain
Zipper
Piece of fabric
Measuring tape
Glue gun
Pins
Seam ripper
Scissors
Stuffed animal
Chain
Zipper
Piece of fabric
Measuring tape
Glue gun
Pins
Seam ripper
Scissors
Step 1: Seam Ripping and Unstufing
seam rip a opening at the top of the animal & take out some of the stuffing
Step 2: Measure
measure the length of the hole you made also measure the width . I got 3" length and 2" width
Step 3: Measure and Cut
on your piece of fabric measure out the measurements you got. Put the fabric on fold then cut it out you should have two pieces.
Step 4: Sew or Glue
you can either sew or glue the pieces together I sewed mine. Make sure you only sew along the lines I made
Step 5: Pull
after you sewed or glued it , pull it inside so that it's a bag.
Step 6: Pin Then Sew or Glue
Pin your zipper down to your fabric. Then you can either sew or glue it down. I sewed mine
Step 7: Pin and Glue
Pin your zipper to the animal . Put the bag in it then pin it. Then glue it to the animal
Step 8: Measure and Cut
Put your chain around you how you would wear the purse. Then measure how long it is. If you have a thick chain use pliers to cut them , but if you have a thin chain use scissors. I put mine over my opposite shoulder. And it was 44".
Step 9: Use Jump Rings
You can either glue the chain down or use jump rings to connect the chain to the purse with no glue. I just used the last of my jump rings on my record purse. So I'm going to glue mine.
If you used jump rings your all done if not keep going
Step 10: Seam Rip
I seam ripped one little hole on each side of the animal to put the chain in.
Step 11: Glue
Glue the chain in the hole . Then your done!!
