Introduction: Stylish Tinfoil Crane Bird
About: Am an Artist, like to do ARts and Crafts
Hi Friends, i hope everyone is doing good.
Today am going to show you how to use your hands to copy carve any statue with tinfoil or aluminum foil paper.
Step 1: Materials Required
Everyone can get these materials which is already available in your home.
1, Any statue of your choice
2, Tinfoil or Aluminum foil
3, soft wooden stick ( for shaping)
4, Fevi quick or quick fix
5, sissors or cutter
6, 2 dry wooden bark from any plant
Step 2: Wrap the Statue Roughly With Tin Foil
1, Take a sheet of tinfoil and roughly wrap it on outer side of the statue.
2, Just use your fingers to wrap it tight to make sure the foil blends with the shape of statue.
Step 3: Start Shaping the Foil Using Wooden Stick
1, Use the sharp point of wooden stick for shaping the nook points to copy the texture.( Refer Image 1 )
2, Use the thick point of wooden stick to shape the curves as shown in Image 2.
Note : Don't use hard wood for shaping, hard wood will tear the foil when its rubbed hard.
Step 4: Cut the Excess Foil and Pull Out the Statue Gently
1, Once shaping is finished just cut the excess foil as shown in image 1.
2. After cutting the excess material once again shape the edges of the foil to match the statue. Refer image 2
3, After shaping it gently pull out the foil from the statue ( dont be hard while pulling out, handle gently ) refer Image 3.
4 Once foil is pulled out from statue it will look as shown in image 4
Step 5: Glu the Open Ends and Legs
1, Use quick fix to attach the open ends instantly, refer image 1
2, Use dry barks as legs, cut them to equal size and wrap it with the legs of foil and apply quick fix refer image 2 and 3
Step 6: Photo Session
Here is the final product made from tin foil.
its a simple and easy process even a child can do this basic shapping and rubbing the curves.
so friends have a try and teach your chindrens to improve their art work
Good Luck to all my future Foil statue makers
