Introduction: Sugru Toothbrush Grip
About: I am bond. B-O-N-D
In this step by step tutorial,
i will show you how to make a sugru grip for your toothbrush(you can even use it for a shaver!)
By the end of this instructable, you will have a comfortable brush/shave:)
Step 1: Materials
1) tooth brush/shaver
2) a pack of sugru
3) time and patience
If you need sugru, you can buy it in the link below!!
https://sugru.com/buy
Step 2: Find a Toothbrush Ar Shaver
For this step, all you need to do is locate a toothbrush(or shaver) that you use the most.
Step 3: Mark Where You Usually Brush.
Take your toothbrush/razor, and grasp it like you would when you usually brush your teeth or shave.
Make note of where you hands are placed on the brush/razor
then take a sharpie and make some marks on where your hands are when you brush.
Step 4: Apply the Sugru!
cover the whole area that you marked, with some sugru!
when the whole area is coverd, squeeze the sugru with your hand as you would normally brush your teeth,
this will leave an indentation in the surgu, so you can have a comfortable brush!
Now, this is where the patience comes in, because you need to let it dry overnight!
Step 5: Finished!
Now, your sugru should be dry!
now go on and brush your teeth/shave your face with comfort!
