Introduction: Sun Spotter Solar Eclipse Viewer
On August I will travel to the USA so experience the total eclipse.Because I am traveling on a very low-cost fare, I cannot take a big telescope or tripod.
I will only take my Nikon D70s camera, a small tripod on a small backpack the fits in the airplane cabin.
So I made this "Sun Spotter device, to see the sun during the eclipse using the 210 mm lens from the camera and a scope adaptor.
Looking directly at the sun, even when it is partially covered by the moon, can cause serious eye damage or blindness. NEVER look at a partial solar eclipse without proper eye protection.
Step 1: Choosing the Lens
First I had to decide what lens to use.
In previous project (Venus transit) I used my Old 500 mm Nikkor reflector, but it is way too big for carrying it the trip.
I have seen other projects in Instructables using binoculars or readings glasses, it is difficult to attach a plate as a shade in the front of the binucular.
Using a reading glasses lens gives a good sun image as origamiwolf did gives a good sun image but the device is big and the projection screen has to be far apart or need to use a mirror.. and a lot of parts to take in the trip.
Because anyway I am taking my Camera (NkonD70s) I opted for using the Nikkor zoom 70-210.
Step 2: Attaching the Lens to the Tripod
The problem is that you cannot attach the lens to a tripod without a camera so I had to make and adaptor to attach it.
I used a 1/4" nut (that is the standard thread for a tripod screw and molded a base to the lens using epoxy putty.
I wrap the putty in saran wrap so it won't stick to the lens or tripod. when the putty is fully I attached it to the lens using a metal adjustable band.
Step 3: The Nikon Lens Scope Adapter
Unfortunately, this incredible device is no longer made by Nikon
You attach the 210mm lens ant it converts it to 20x scope
I bought mine a few years ago from Ebay.
Step 4: The Shade Anf Filter Holder
This piece of 5mm plywood (25cm x 25cm) is the base of the construction.
in the center, I made a 6mm diameter hole of and carefully sanded it to fit and glue a 62mm UV filter.
two more holes near the border, one to hold a perpendicular screw that will be used as a pointer.
When there is no shadow the lens perfectly aligned to the sun.
The other hold is used to screw the metal threaded rod that will hold the projection screen.
I also glued metal washers to the plate to keep everything firm and perpendicular.
Step 5: The Projection Screen
For the projection screen, I choose 8mm Foam Cardboard (20cm x 21 cm)
It is very lightweight and sturdy.
I used metal washers here too to keep the rod perpendicular to the screen.
Step 6: Putting All Together
Enjoy and again:
