Introduction: Super Bright Torch! Rechargeable!
Hi Friends, Today we will Make a Powerfull and Long Lasting Torch.And... It's Rechargeable too!
Step 1: Parts Needed
Parts Needed for this Project :-
1.Li-ion 3.7v Battery
2.1N4007 Zener Diode
3. (2) 5mm Led's
4. (1) 10mm Led
5. (1)5mm Blue Led
6. DC Jack
7. Switch
8. Lighter
9. Glue Stick and Soldering Iron
10. 220 Ohms Resistor
3. (2) 5mm Led's
4. (1) 10mm Led
5. (1)5mm Blue Led
6. DC Jack
7. Switch
8. Lighter
Step 2: Designing Layouts for Cutting/Melting Plastic
As i was not having drill so i did through a Cheap method, that just heat up your skrewdriver and Melt the plastic thus making a perfect Hole :D. I Prefer Drill for those who want Clean Holes.
Just Make Sure that You Drill/Melt a Big Hole for Big Led.
Step 3: The Schematic
So Here is the Schematic Pretty Simple.
Donot Forget About the Zener Diode Which will Mostly Prevent the back flow from battery.
*Warning* - There is a LOT of RISK in charging the Batttery Directly from the 5v Mobile wall Charger so,Be Careful and I will NOT be Responsible if any Wrong Thing Happens.
Don't Forget that the Charging Time of Battery should be only be 50 min when it is empty and charged Directly From 5v Wall Mobile Charger.Otherwise Batttery could Explode if Over - Charging is Done.
Step 4: Hot Gluing and Soldering
Now Hot Glue All the Parts and Connect Wires Acording to the Schematic. After this it is optional to hot glue the bare Wire to Seal them.
I Used Lighter to Melt the Glue Stick (if you have an hot glue machine then do with it :P)
Step 5: Fully Assembled!
Step 6: Black Taping All Sides to Seal It
You can use Spray paint but it should be done before Making so to save some money i used Black Tape.
Step 7: Testing the Brightness!
Because of the Big Led It Gives Very much Brightnesss.
Pocket Torch for Everybody which is Simple and can be made by Anyone!
Just 7 Easy Steps :)
