Introduction: Super Easy Led Lamp
A Led lamp that you can make in just a few simple steps.
Step 1: Supplies
9 volt battery snap
9 volt battery
3 colored LEDs (I used blue)
1 glass jar
paper
tape (clear is best)
9 volt battery snap
9 volt battery
1 glass jar
paper
Step 2: Step 1
Solder the leds together in series (the positive lead connected to a negative on a different LED and so on). Next solder the ends of the LEDs to the ends of the battery snap (make sure you put negative with negative etc.)(the red wire is positive). Then just tape the leds to the battery (point the LEDs different ways so they spread the light better) it should then look like this.
Step 3: Step 2
line the inside of the jar with paper to help diffuse the light (you can also attack the LEDs with sandpaper) (supposedly that works) it should then look something like this.
Step 4: Step 4
snap the Leds to the battery sit the whole bundle in the middle of the jar, sit back and bask in the awesome glowing light.
