Introduction: Swirly Paperclip Bracelet
Not your average 'string some clips together ' bracelet! This one was born of hours of frustration in front of a PC with 'network problems'. Instead of throwing the monitor out of the window, I started mutilating office supplies and a lovely accessory was born, Please take a moment to vote for me while you are here!!! I have been lusting after an Epilog Laser Cutter for quite a while!! Also, check out my other tutorials for more jewelry ideas! Thanks!!!
Step 1: What You Need
  • Paperclips
  • Needle nose pliers (or looping pliers if you have them)
  •  A clasp
  • Jump rings
Step 2: Straighten
Unbend your paperclip. Get it as straightened as you can.
Step 3: Make a Spiral
Grasp one end with your pliers and with your other hand wrap it around the end of your pliers as tightly as you can, forming a loop. Remove the loop from the pliers and turn it sideways so you are holding it flatly with the pliers. Pull the straight part of the wire around the loop, making subsequently larger circles around the original loop. Stop about half way up the paperclip
Step 4: Swirl the Other Side
Flip the clip and follow the same steps to make a spiral going the opposite direction on the other side.
Step 5: Repeat Repeat Repeat
To make a single strand you need to make 7-8 links, depending on the size of your wrist.
Step 6: Chain the Links Together
Open a jump ring and place two clips on the ring. Close the ring. Add two more jump rings in the same manner.
Step 7: Just Keep Linking
Add your remaining links in the same manner, until the chain is long enough to fit comfortably around your wrist.
Step 8: Clasp
Add a single jump ring to one end of the chain. On the other end, add a jump ring and a clasp. Close the jump ring tightly.
Step 9: Ta-da!
Wear your new bracelet with pride and remember that even if the *#%**@ computer doesn't work, you CAN still do something!
