Introduction: Swiss Steak Recipie
I had this for a meal once and remember being impressed at how tender and delicious the meat was, definitely a "comfort" dish in my book. This recipe is simple, and unique to me because I don't often use so much tomato with beef together. The recipe is not my own, but a good, solid starting point. Feel free to tweak it and post your savory outcomes!
Serve with oven baked or mashed potatoes, and green beans, if your into that kind of thing!
Pairs nicely with a white wine!
Like I said this is not my own recipe but a great place to start:
INGREDIENTS
One 2 to 2.5 pound round or top round steak, about an inch thick
A couple tablespoons of flour
Salt and pepper
3 Tbsp grapeseed oil, or other high smoke point oil for browning (canola)
1 onion, roughly chopped
1 clove garlic, chopped
2 cups puréed tomatoes (canned or fresh)
2 teaspoons each of fresh thyme, sage, marjoram, or 1/2 teaspoon each of dried
Preperation:
1 Rub flour into both sides of the steak. Sprinkle with salt and pepper. Heat a wide, shallow (3 inches), covered pan to medium high heat. Add 2 Tbsp of oil to coat the pan. Place the steak in the pan, and cook for approximately 10 minutes on each side, enough to brown the steak.
2. Remove the steak from the pan and set aside. Add onions and garlic to the pan and another tablespoon of oil. Cook the onions and garlic for 3-5 minutes, using a metal spatula to scrape up any steak drippings (the only thing I would change here is to deglaze the pan with a nice white wine!), mixing them in with the onions. Add half of the herbs to the onions. Return the steak to the pan, placing it on top of the onions. Crowd the onions around and on top of the steak. Sprinkle the rest of the herbs on top of the steak. Add the 2 cups of puréed tomatoes to the pan.
3. Cover the pan with a tight fitting lid. Use a high lid if available. A high lid will help circulate the steam and moisture from the cooking juices and keep the steak moist. Bring the steak in the tomato purée to a simmer and then lower the heat to the lowest heat possible to maintain a low simmer (we use the warm setting on our electric range).
4. Cook for 1 1/2 hours. While the steak is cooking, you may want to slightly pre-cook vegetables that you want to serve with the steak. For example, for this dish we steamed 4 small, peeled, quartered russet potatoes and 2 carrots, quartered lengthwise and cut into 2 inch segments, for 5-10 minutes. (You could use other vegetables, such as green beans, or no vegetables at all.) After 1 1/2 hours of cooking time for the steak, we uncovered the pan, turned the steak over, added the potatoes and carrots, covered the pan and cooked the steak and vegetables for another 30 minutes.
The reason that you might want to pre-cook the vegetables a bit first is that the steak is cooking at a very low heat. You'll have more control over how cooked the vegetables are if you pre-cook them a bit first.
5. The steak should be done after a total cooking time of 2 hours. To check it, you can poke it with a fork. The meat should be quite tender. To serve, remove the steak and slice it on a carving board. Alternatively, you could have started with individual steaks that were smaller. Spoon the sauce over the steak.
Recipie from: http://www.simplyrecipes.com/recipes/swiss_steak/
INGREDIENTS
Salt and pepper
Preperation:
