Introduction: T-Shirt Tank
Follow the instructions to make your own racer back t-shirt tank from an old t-shirt!
You will need the following:
Tools:
Scissors
Materials:
T-Shirt
Tools:
Scissors
Materials:
T-Shirt
Step 1:
1. Lay T-shirt smoothly on a flat surface such as a table or the floor
Step 2:
2. Cut along the seam of each arm hole to cut off each sleeve.
NOTE: Keep all scraps until finished
Step 3:
3. Cut along the seam of the neckline to cut off the neckline
Step 4:
4. Cut the neckline piece so it is in one long strand instead of a circle
Step 5:
5. Flip the shirt over so the back is facing you
Step 6:
6. Slide the neckline scrap between the front and back of the shirt through the cutoff sleeve holes
Step 7:
7. Tie a knot around the racerback and wrap the rest of the scrap around the back of the racerback. Pull it back to the front and tie another knot.
Step 8:
8. Repeat step 7 and slide the ends of the scrap into the knots
Step 9:
9. Try on the tank and trim any excess t-shirt material from around the neckline and the arm holes
