Introduction: (T.B.A.P) Thunder Bolt Assault Pistol
Here is the T.B.A.P or Thunder Bolt Assault Pistol. Nothing too new just a Oodammo gun with great range and accuracy. It has a 20 round mag, true trigger, trigger guard, sight, and a comfortable handle. It holds enough bullets to last a round at war. Which eliminates reloading on the field. Has a range of 55-60 feet, (silentassasin21 got 135 feet with a mag mod) and the accuracy of a sniper. One of the new things on the gun is the ram lock. It prevents the ram from being pulled out of the back of the gun when doing rapid fire.
Over all this is a great gun for war. I now I'll be using it soon.
Does it sound good?? What do you think?? It only takes ten seconds, so reply!!
Also don't forget to
SUBSCRIBE
Killer~SafeCracker
EDIT: This gun reached 4.27 stars. First place for knex.
SUBSCRIBE
Killer~SafeCracker
Step 1: Part Count.
No one likes running out of parts in the middle of a build. So I made a piece count for you.
Connectors:
Blue---------------------------8
Yellow------------------------28
Green-------------------------8
Red----------------------------8
Light Gray--------------------2
Orange-----------------------7
Rods:
Black/Gray-------------------1
Red----------------------------1
White--------------------------28
Green-------------------------70
Odds and Ends:
Y connectors----------------18
Blue and Black hinges----3
Ball socket-------------------4
Ball joint-----------------------1
Tan clip------------------------4
Blue clip-----------------------4
Rubberbands---------------4
Connectors:
Rods:
Odds and Ends:
Step 2: Step 1
Picture 1: Build two of these.
Picture 2: Build this. (Sorry for the fuzzy pictures my camera is bad)
Picture 3: Add white rods.
Picture 4: Add white rods to one panel.
Picture 5: Add this part.
Picture 6: Make this.
Picture 7: Build this. (Read the note)
Picture 8 Build this.
Picture 9: Get these.
You will need a blue clip in the next step so get it.
Step 3: Step 2
I hope the pictures are not so bad you can't understand them ,but I can't take more so it will have to do.
Picture 1: Add the green connector and blue clip.
Picture 2: Add this part. Sorry for the blur.
Picture 3: Add the trigger.
Step 4: Step 3
In this step we will add the barrel.
Picture 1: Add the white rod to this part.
Picture 2: Add it to the gun. (Again a bad picture but I think you can get it.)
Picture 3: Add this part.
Picture 4: Add the last part of the barrel.
Almost done.
Almost done.
Step 5: Check
Okay this is what you should have built so far.
Step 6: Step 4
Picture 1-2: Now add the other side of the gun.
Picture 3: Add these two parts together.
Picture 4: Add it to the gun.
Step 7: Loading
Picture 1: Build these things.
Picture 2: Load 20 pieces of Oodammo onto the mag.
Picture 3: Snap the mag into place.
Picture 4: Put the ram into the gun and add the rubberbands.
Picture 5: Add a weak band on the mag like shown and your ready.
Step 8: You Are Done!!!
Good job, Your done.
If you have any questions feel free to ask.
Killer~SafeCracker.
Killer~SafeCracker.
