Introduction: TDA2030 Make Amplifier Circuit
About: Professional Electrician, Youtuber & Digital Marketer
In this project circuit, we are going to teach you making a superb quality professional amplifier circuit. It a very powerful amplifier circuit that can produce clear and crystal sound in a very cheap price.
To make this amplifier circuit, we are using DC-12v power supply circuit. The power supply contain 3 ampere. You also can use 12v battery as a power supply circuit. But you should not use High ampere battery.
The article is being published in collaboration with JLCPCB. JLCPCB makes cheapest but top quality PCBs possibly because of scale effect, extremely high production efficiency and less manpower cost.
We also thanks to our sponsor JLCPCB https://jlcpcb.com/RTA for sponsoring us PCB for this project.
Thanks To JLCPCB.
$2 for 1-4 Layer PCBs.
Get SMT Coupons - https://jlcpcb.com/RTA
Step 1: Component List
To make this powerful amplifier circuit, we need to use some electronics components. All components with PCB circuit, you can order from JLCPCB. They offer us best quality PCB circuit in a very cheap price.
Component List –
1. Sound IC – TDA 2030
2. Capacitor - 10µf/ 50v
1µf/ 50v
2. Resistor – 220 Ω
680 Ω
18 K Ω
3. Mylar Polyester Film Capacitor – 2A 104J
4. Sound Speaker
5. Audio Input Cable
6. PCB (made by JLCPCB)
7. Power Supply
Step 2: TDA-2030 Pinout
TDA-2030 is a professional sound IC with 12 watt output power. For this sound IC highest input voltage is 12-28v. It’s 5 leg have 5 different names. If we count it’s leg from left side, then 1st leg non-inverting input, 2nd leg inverting input, 3rd leg –ve, 4th leg O/P and 5th leg +ve.
Step 3: Schematic and PCB Design
The final circuit diagram and design can be seen above. They use online ordering system, professional and efficient customer service, digital manufacturing technology, full-automatic production lines, and stable logistics partners make every step to deliver you PCBs faster.
Their PCB technology allows us to provide high precision boards suitable for industrial, military, aerospace, and medical applications.
Step 4: Connect Resistor With Sound IC
To make this amplifier circuit, 1st we connect 18 K Ω resistor with 1no leg of sound IC. Then we connect 680 Ω resistor with 2no leg of sound IC. To make this amplifier circuit we are using 18 K Ω resistor resistor. We connect another 18 K Ω resistor with 2 and 4no leg of sound IC.
Then we connect the last resistor with this amplifier circuit. We connect 220 Ω resistor with 4no leg of sound IC.
Step 5: Connect Electrolytic Capacitor With Amplifier
Now we need to connect electrolytic capacitor with the amplifier circuit. 1st we connect 1µf/ 50v capacitor with the amplifier circuit. We connect this capacitor positive leg with 1no leg of sound IC.
This time, I’ll connect 10µf/ 50v capacitor with the circuit. We connect this capacitor positive leg with empty terminal of 680 Ω resistor.
Connect another capacitor positive leg with empty terminal of 220 Ω resistor.
Step 6: Connect Mylar Polyester Film Capacitor
We need to make a parallel connection with mylar polyester film capacitor and 220µf/25v capacitor. We make two pieces parallel connection.
Now connect capacitor negative leg with 3no leg of sound IC and connect another capacitor positive leg with 5no leg of sound IC.
Step 7: ​Make Ground Connection
To input ground voltage, we need to make ground connection for this amplifier circuit. We connect all empty leg of resistor and capacitor.
Then cut-off extra leg of all electronics component.
Step 8: Connect Audio Input Cable
For output audio, 1st we need to input audio at this amplifier circuit. We connect 3.5mm audio input cable ground cable with ground leg of amplifier circuit and connect L/R cable with negative leg of 1µf/ 50v capacitor.
Step 9: Connect Sound Speaker
For output sound, now we need to connect a better quality sound speaker with the amplifier circuit. We connect one speaker cable with ground leg of amplifier and connect another speaker cable with 4no leg of sound IC.
Step 10: Connect Power Supply
Now we connect a power supply adapter with the amplifier circuit. We are using DC-12v (3 amp) power supply with the amplifier circuit. Connect 12v positive cable with 5no leg and negative cable with 3no leg of TDA2030 sound IC.
It is the time to connect sound IC with heat-sink.
Now just Plug-in 3.5mm audio input cable and power supply with amplifier circuit. Then enjoy the music.
