Introduction: TIC TAC FLASH LIGHT (solar Powered)
During the rainy season we have power cuts a lot of time . So ,this is a small flashlight made out of reused materials.
It runs on solar energy and is very cheap and simple to make .
Step 1: MATERIALS REQUIRED.
MATERIALS
1. TIC TAC box
2. An L.E.D
3. A battery of 3.7 v (i salvaged mine from a broken MP4)
4. A small solar panel (I salvaged it from a calculator)
5. A diode
TOOLS
1. A soldering iron
2. Scissors (optional)
Step 2: MOUNTING THE LED
After collecting the materials ,we have to mount the L.E.D on top of the TIC TAC box.Make a hole in it using soldering iron or scissors according to the size of L.E.D. The L.E.D should fit into it perfectly.
Step 3: MOUNTING THE SOLAR PANEL
After mounting the L.E.D we have to mount the solar panel onto the box. Make a hole in the box where the positive and the negative terminals go and pass the wires (terminal wires) through it. And then stick it onto the box using hot glue/fevibond/etc.
Sorry - I forgot to take the photos
Step 4: MOUNTING THE SWITCH
Just like that of the solar panels,make two holes where the wire would go, pass the wires through the holes and mount the switch using hotglue/fevibond/etc. I mounted the switch on the side of the box.
Step 5: CONNECTING THE CIRCUIT
After mounting the L.E.D ,solar panel ,and the switch we now have to connect the circuit. Connect everything according to the schematic given above .
Step 6: FINISHING
After connecting the circuit ,insert the battery into the box and close it.if wanted you can decorate it.
