Introduction: TJ-ASTR - the Jamalam's Assault Rifle
About: Figured it was high time to give this a quick edit. I was an active part of the K'Nex community from about '08, I still occasionally lurk. I did a lot of dumb stuff on here but I'm past it now. I'm currently s…
Hi, this is my newest assault rifle. DJ Radio asked me to post it, so I did. It shoots 2 white rods 40 ft, has a removable mag, with a new system: the mag completes the mag well/barrel, so there is no fuss over transferring the ammo from the mag to the well.
Pros
Shoots 40 ft
True trigger
shoots 2 white rods to give a shotgun effect
Hurts like hell if you get shot
New mag with new system
Cons
The firing pin gets stuck if you bring it back too far
Nothing too new about it, other than the mag
Step 1: Handle and Trigger
Here we make the handle and trigger. I hope you knew that.
Step 2: Stock
Make the stock and attach to the handle
Step 3: Main Body
Make the main body and attach to what you already have
Step 4: Magazine
Here make the removeable mag and learn how to attach/detach it
Step 5: Adding Rubberbands, Loading and Firing
here, put the rubberbands on.
To load, put as many white rods as you want inside the mag, then put a blue rod in where it is on the video. Then attach the mag. (you can carry around lots of mags!)
Then, to fire, pull the pin back, and pull the trigger!
Any questions, comment here.
The Jamalam
