Introduction: TRASH TO TREASURE
My wife and I recently purchased some grey blinds for our living room and we wanted some nice unique tie backs to go with them. Given the fact that I am a keen upcycler and hate buying new things, when you can make something nicer.
Step 1: Hearts!
I made these using some scrap 8mm birch plywood, that I salvaged from an industrial estate. Make sure you have the owners permission, which I did. It was beaten up in places but I had enough to cut out two Hearts using a Jigsaw. Carefully following a template that I mounted to the board using spray adhesive.
Step 2: Paint.
I applied two base coats of grey spray primer, sanding in-between each one using 200 grit sandpaper to get it smooth and then two coats of white. After that had dried I sanded using 80 grit to show the grey below and some wood to achieve a shabby chic look. Lastly two coats of clear matt varnish.
Step 3: Done.
I then drilled two holes and used some 12mm natural braided twine to use as tie backs. This was done by feeding one end through and looping over to from a loop, the one end is then fixed on the back of the heart using heavy duty staples. I then repeated this for the other hole to have two loops.
Overall I am really happy with how these turned out and they really are a trash to treasure item.
Appreciate any comments that you have and would love to see any examples that you might have.
Thanks,
Happy Making.
Also if you liked this, don't forget to give it a vote.
