Introduction: Taffy Twist
I will be showing you how to make a rainbow taffy twist(infinity bracelet)
Step 1: Materials
You will need a loom,elastics,a hook,and a clip
Step 2: Placing the Outline
Turn your loom so the arrow is facing away from you and place your out side bands starting with the left side
Step 3: The Twists
Make an 8 with one or two bands and place it on the second two pegs,repeat until the second last peg turn your loom around and place a capping band which is an 8 with both sides on one finger/hook
Step 4: Hooking
Take your hook and put it inside the capping band take the first elastic besides the capping band and place the first one to the left and the next one to the right now take the bottom band of each peg on the left row and hook it over to the top it should look like a tear drop and repeat on the right row. Your final product should look like mine
Step 5: Taking Off the Loom
Have the loom so the arrow is facing away from you. What I do is take one single band if the outline colour and use my hook to pick up the end bands and gently pull it off the loom so no bands break
Step 6: Extensions
My wrist is small so I use 4 bands for my extension take a single band and pull it through the band that all of the end bands are on take another and pull it through until it fits and put your clip on and you finished!
