Introduction: Temperature and Humidity Using ESP32-DHT22-MQTT-MySQL-PHP
My girlfriend wanted a glasshouse, so I made her one. But I wanted a temperature and humidity sensor inside the glasshouse. So, I googled for examples and started experimenting.
My conclusion was that all the examples that I found were not exactly what I wanted to build. I grabbed a lot of little parts of code and combined them. It took me quite a while to finish my first working build because the documentation of most examples were too difficult for me to understand or they assumed part that I should know?? But I didn’t know nothing (yet) ☹
That’s why I build this instructable. A “beginning-until the end” tutorial for literally everybody to understand. (At least I hope 😊)
How it works ...
- The end-product is an ESP32-CAM with a DHT22 sensor attached to it which get’s it power from a 18650 battery. Every three minutes it reads the temperature and humidity and sends this over WiFi to an external MQTT server and then goes to sleep (for three minutes) to use as less battery as needed.
- On a Debian server, (which could also be a raspberry pi I guess) I have python3, a MQTT server, a MySQL server and a webserver.
- The python3 script runs as a service and whenever it receives a MQTT message, it counts the previous number of entries (index number) and increments this by one. Then it reads the values of the temperature and the humidity from the MQTT message. It checks for false values and whenever the values are correct, it sends the values together with the new index number and the current date and time to a MySQL server.
- The webserver has a PHP script which reads the values from the MySQL server and makes a nice graph from it using Google Charts. (example)
The parts I used are the following:
- ESP32-CAM (The reason I used the cam version is because it has an external antenna connector on it. There are probably also other ESP32’s you could use)
- External antenna
- AM2302 DHT22 sensor (This one has a built-in resistor, so you only need three wires)
- 18650 battery shield v3
- 18650 battery (NCR18650B)
- Old micro USB cable (for connecting the ESP32 to the battery shield)
- Some short jumper wires
Extra needed:
Step 1: Upload the Arduino Code to the ESP32-CAM
So let’s begin!
To upload the Arduino code to the ESP32-CAM, you have to connect the USBtoTTL connector to the ESP32 using the schematics above.
The Arduino code is:
/*Just a little program to read the temperature and humidity from a DHT22 sensor and pass it to MQTT. B. Duijnhouwer June, 8th 2020 */ #include <WiFi.h> #include <PubSubClient.h> #include <dht.h> #define wifi_ssid "***WIFI_SSID***" //wifi ssid #define wifi_password "***WIFI_PASSWORD***" //wifi password #define mqtt_server "***SERVER_NAME***" // server name or IP #define mqtt_user "***MQTT_USER***" // username #define mqtt_password "***MQTT_PASSWORD***" // password #define topic "glasshouse/dhtreadings" #define debug_topic "glasshouse/debug" //Topic for debugging /* definitions for deepsleep */ #define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds */ #define TIME_TO_SLEEP 180 /* Time ESP32 will go to sleep for 5 minutes (in seconds) */ bool debug = true; //Display log message if True #define DHT22_PIN 14 dht DHT; WiFiClient espClient; PubSubClient client(espClient); char data[80]; void setup() { Serial.begin(115200); setup_wifi(); //Connect to Wifi network client.setServer(mqtt_server, 1883); // Configure MQTT connection, change port if needed. if (!client.connected()) { reconnect(); } // READ DATA int chk = DHT.read22(DHT22_PIN); float t = DHT.temperature; float h = DHT.humidity; String dhtReadings = "{\"temperature\":\"" + String(t) + "\", \"humidity\":\"" + String(h) + "\"}"; dhtReadings.toCharArray(data, (dhtReadings.length() + 1)); if ( debug ) { Serial.print("Temperature : "); Serial.print(t); Serial.print(" | Humidity : "); Serial.println(h); } // Publish values to MQTT topics client.publish(topic, data); // Publish readings on topic (glasshouse/dhtreadings) if ( debug ) { Serial.println("Readings sent to MQTT."); } esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR); //go to sleep Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) + " Seconds"); Serial.println("Going to sleep as normal now."); esp_deep_sleep_start(); } //Setup connection to wifi void setup_wifi() { delay(20); Serial.println(); Serial.print("Connecting to "); Serial.println(wifi_ssid); WiFi.begin(wifi_ssid, wifi_password); while (WiFi.status() != WL_CONNECTED) { delay(100); Serial.print("."); } Serial.println(""); Serial.println("WiFi is OK "); Serial.print("=> ESP32 new IP address is: "); Serial.print(WiFi.localIP()); Serial.println(""); } //Reconnect to wifi if connection is lost void reconnect() { while (!client.connected()) { Serial.print("Connecting to MQTT broker ..."); if (client.connect("ESP32Client", mqtt_user, mqtt_password)) { Serial.println("OK"); } else { Serial.print("[Error] Not connected: "); Serial.print(client.state()); Serial.println("Wait 5 seconds before retry."); delay(5000); } } } void loop() { }
And again, don't forget to replace the credentials with your own credentials!
Step 2: Wire Up!
For the power, I used an old USB cable of which I cut off the USB-A connector. There are four wires in the USB cable, we only need the black and the red ones.
So, connect everything according to the schedule above.
Step 3: Python3 Script
The Python3 script goes into a place where it’s accessible to the root user.
I used /root/scripts/glasshouse/glasshouse.py for this script.
The contents of the python script is:
# Python3 script to connect to MQTT, read values and write them into MySQL # # B. Duijnhouwer # June, 8th 2020 # # version: 1.0 # # import paho.mqtt.client as mqtt import json import pymysql pymysql.install_as_MySQLdb() import MySQLdb from datetime import datetime db= MySQLdb.connect("localhost", "glasshouse", "***MYSQL_USERNAME***", "***MYSQL_PASSWORD***") cursor=db.cursor() broker_address= "localhost" #Broker address port = 1883 #Broker port user = "***MQTT_USERNAME***" #Connection username password = "***MQTT_PASSWORD***" #Connection password def on_connect(client, userdata, flags, rc): # The callback for when the client connects to the broker print("Connected with result code {0}".format(str(rc))) # Print result of connection attempt client.subscribe("glasshouse/dhtreadings/#") def on_message(client, userdata, msg): # The callback for when a PUBLISH message is received from the server. cursor.execute ("select * from sensordata") numrows = int (cursor.rowcount) newrow = numrows + 1 now = datetime.now() formatted_date = now.strftime('%Y-%m-%d %H:%M:%S') payload = json.loads(msg.payload.decode('utf-8')) print("New row: "+str(newrow)) temperature = float(payload["temperature"]) humidity = float(payload["humidity"]) print("Temperature: "+str(temperature)) print("Humidity: "+str(humidity)) print("DateTime: "+str(formatted_date)) if (( temperature > -20) and (temperature < 40)) and ((humidity >= 0) and (humidity <= 100)): cur = db.cursor() cur.execute("INSERT INTO glasshouse.sensordata (idx, temperature, humidity, timestamp) VALUES ("+str(newrow)+", "+str(temperature)+", "+str(humidity)+", %s)", (formatted_date)) db.commit() print("data received and imported in MySQL") else: print("data exceeded limits and is NOT imported in MySQL") client = mqtt.Client("duijnhouwer-com-glasshouse-script") client.username_pw_set(user, password=password) client.on_connect = on_connect # Define callback function for successful connection client.on_message = on_message # Define callback function for receipt of a message client.connect(broker_address, port=port) #connect to broker client.loop_forever() # Start networking daemon
Don't forget to replace the MySQL username and password and the MQTT username and password to your own credentials !
You can make the script run as a service by creating two files.
The first one is “/etc/init/glasshouse.conf” with the following contents:
start on runlevel [2345] stop on runlevel [!2345] exec /root/scripts/glasshouse/glasshouse.py
The second one is “/etc/systemd/system/multi-user.target.wants/glasshouse.service”
[Unit] Description=Glasshouse Monitoring Service After=multi-user.target <br>[Service] Type=simple Restart=always RestartSec=1 ExecStart=/usr/bin/python3 /root/scripts/glasshouse/glasshouse.py [Install] WantedBy=multi-user.target
You can make this run as a service using the following command:
systemctl enable glasshouse
and start it using:
systemctl start glasshouse
Step 4: MySQL Server
You have to create a new MySQL database with just one table in it.
The code for creating the table is:
CREATE TABLE `sensordata` ( `idx` int(11) DEFAULT NULL, `temperature` float DEFAULT NULL, `humidity` float DEFAULT NULL, `timestamp` datetime DEFAULT NULL ) ENGINE=InnoDB DEFAULT CHARSET=utf8;
Step 5: Webserver
The webserver has two files, the index.php file and one config.ini file
The contents of the config.ini file is:
[database] db_host = "localhost" db_name = "glasshouse" db_table = "sensordata" db_user = "***DATABASE_USER***" db_password = "***DATABASE_PASSWORD***"
Where offcourse you replace ***DATABASE_USER*** and ***DATABASE_PASSWORD*** with your own credentials.
<?php # Loading config data from *.ini-file $ini = parse_ini_file ('config.ini'); # Assigning the ini-values to usable variables $db_host = $ini['db_host']; $db_name = $ini['db_name']; $db_table = $ini['db_table']; $db_user = $ini['db_user']; $db_password = $ini['db_password']; # Prepare a connection to the mySQL database $connection = new mysqli($db_host, $db_user, $db_password, $db_name); ?> <!-- start of the HTML part that Google Chart needs --> <html> <head> <script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script> <!-- This loads the 'corechart' package. --> <script type="text/javascript"> google.charts.load('current', {'packages':['corechart']}); google.charts.setOnLoadCallback(drawChart); function drawChart() { var data = google.visualization.arrayToDataTable([ // ['Timestamp', 'Temperature', 'Humidity', 'Heat Index'], ['Timestamp', 'Temperature', 'Humidity'], <?php # This query connects to the database and get the last 10 readings $sql = "SELECT temperature, humidity, timestamp FROM $db_table"; $result = $connection->query($sql); # This while - loop formats and put all the retrieved data into ['timestamp', 'temperature', 'humidity'] way. while ($row = $result->fetch_assoc()) { $timestamp_rest = substr($row["timestamp"],10,6); echo "['".$timestamp_rest."',".$row['temperature'].",".$row['humidity']."],"; // echo "['".$timestamp_rest."',".$row['temperature'].",".$row['humidity'].",".$row['heatindex']."],"; } ?> ]); // Curved line var options = { title: 'Temperature and humidity', curveType: 'function', legend: { position: 'bottom' }, hAxis: { slantedText:true, slantedTextAngle:45 } }; // Curved chart var chart = new google.visualization.LineChart(document.getElementById('curve_chart')); chart.draw(data, options); } // End bracket from drawChart //</script> <!-- The charts below is ony available in the 'bar' package --> <script type="text/javascript"> </script> </head> <?php # Prepare a connection to the mySQL database $connection = new mysqli($db_host, $db_user, $db_password, $db_name); ?> <div id="curve_chart" style="width: 1600px; height: 640px;"></div> <div id="barchart_values" style="width: 900px; height: 480px;"></div> <div id="top_x_div" style="width: 900px; height: 480px;"></div>
Step 6: 3D Printed Housing
For the housing, I used two separate housings, one for the ESP32-CAM and DHT22 together and one for the 18650 battery shield.
Step 7: The Final Result!
The final result is also shown in the pictures above.
And whenever the battery is empty, you can charge it with a mini USB cable.
