Introduction: Temperature Logger With Pro Mini & Battery Only
This is a minimal system for logging temperature.
You will need:
  • Arduino pro mini (ATmega328p) - use internal temperature sensor & EEPROM
  • Battery pack or anything else can power up the pro mini - power from 'raw' pin must >= 5V; power from 'vcc' pin, I'm only sure <= 2.75V not work.
  • any USB to UART bridge - FTDI, CP2102, CH340G..etc
Step 1: Attach Battery Pack
attach power for your condition.
Step 2: Program
program as normal arduino pro mini.
You can change the count in sleepMinutes() if you need.
default: 2s * 150 = 300 s = 5 minutes, record every 5 minutes (almost)
void sleepMinutes()
for (unsigned int i = 0; i < 150; i++) {
//for (unsigned int i = 0; i < 1; i++) {
LowPower.powerDown(SLEEP_2S, ADC_OFF, BOD_OFF);
cont++;
Step 3: Log the Temperature
just put on battery and do NOT press reset button,
and it will auto start logging.
Step 4: Read Out Temperature
  1. connect with "USB to UART bridge", for me is CP2102
  2. open serial monitor
  3. if there were data, it should print out automatic
  4. if not, press reset button once
the format is :
  1. current record count in EEPROM
  2. n-th record from boot up
  3. temperature (250 = 25°C)
  4. voltage (mV)
send char to do:
  • 'N' - show current temperature & voltage
  • 'D' - dump all log in EEPROM
  • 'C' - reset counter, next record will start at 0
  • 'R' - dump raw data in EEPROM
  • 'F' - fill EEPROM with 0xFF
