The Introduction of XL6009 Step-up Power Module DC-DC Converter
79K5033
Intro: The Introduction of XL6009 Step-up Power Module DC-DC Converter
ICStation team have developed this new product-XL6009 Step-up Power Module recently.We share the knowledge of this product in details and show you the actual testing results with the digital storage oscilloscope.You could find the information about applicable occasion, feature,function,diagram, and testing results through this article.
Applicable occasion:
1.experiment teaching
2.temporarily set up power supply in the outdoor
3.car(audio, electric fan)power supply
4.industrial power display
Feature:
1.XL6009 Step-up Power Module uses XL6009 as main control chip to realize broader scope of application about boosting.
2.It shows the adjusted results intuitively with the digital tube.
3.There is no need to use the multimeter, which will be more convenient.
4.Equipped with the Schottky diode,you need not to be worried about wrong operation.
5.It adds ventilation hole on PCB to enhance the capacity of heat dissipation.
Tools you need to test:
1.Copper Wire
2.Copper Cylinder
3.Nut
4.Pin Header
5.Screw Driver
6.Power Connector
7.Terminal Wire Connector
Description:
Input voltage:4.2-32V
Output voltage:5-52V
Maximum input current:4A
Transfer efficiency:94%
Output ripple:50mV
Operating temperature:-40℃~+85℃
STEP 1: Function Introduction
①The voltage display
②Indicating input and output voltage area
③Function key:
Short press: input/output display options
Moderate press: Enter the fine-tuning state and increase or decrease the offset(the default is 0). when the voltage display      inaccurate use , you can short press to regulate, long press or long press to restore.
Long press: the state of low power consumption, the digital tube and the lights are out, the normal work of the module. Click the button again to restore. Normal display
④Adjust output voltage :
Clockwise----- increasing voltage
Counterclockwise----reduce the voltage
⑤schottky diode provides protection of reverse connection.
⑥High frequency capacitance to eliminate electric spark
STEP 2: Diagram
STEP 3: Testing Result:Input Voltage 5V
Test condition:
Input voltage:5V
Output voltage:6.2V
The actual testing results:
Output voltage:6.21V
Output ripple:78mv(higher than the description, caused by the power supply by the preliminary analysis)
STEP 4: Testing Result:Input Voltage 30V
Test condition:
Input voltage:30V
Output voltage:52.7V
Output voltage:52.3V
Output ripple: 1.76V(the value of voltage is unstable caused by the low output capacitance and low input current)
Note: When the voltage is much higher, the corresponding current will be higher (at least 3A). Otherwise the power supply will mistaken for short circuit and display abnormally.
29 Comments
Is there any possibilities of replacement of potentiometer with mosfet...i just want to control that potentiometer using MOSFET and pwm from Arduino...i want to control its output automatically by Arduino without rotating the knob manually so is there any possibilities of doing that i tried to put MOSFEt in place of potentiometer but it burns..so can you please help me to make it automatically...
hello Guys,
using the XL6009 I just got my Arduino burned. I used in combination with a Li-ion charging module and photocells. I tested yesterday the set-up and forgot to disconnect it during the night. Now what happened is: The voltage on the battery dropped below 3,5 Volt and in this moment the XL6009 produced an output of 35 Volt.
I just tested this 6009 with a regulated power supply and I tested also a new module and both show the same problem. If the input voltage is above 3,5 Volt you can tune it pretty precise to 12 Volt and it keeps the 12V at any input voltage between 3,5 and 11 Volt, but once the input drops below 3,5 the output rocks up to 35-40V.
Any ideas?
Working with solar panel you can never be on the save side and guarantee that not a day wil come where the voltage drops below 3.5 V.
when we connect load of 12V 2A the voltage suddenly fall down at 5V then what is Problem?
Is this a boost converter or a buck? the title says its a step-up converter which would indicate that this maybe a boost converter. Also could you please tell us what the current ratings at input and output are? As in, if the input voltage is lower than the output voltage then by what margin does the output current reduce as compared to the input?
Thank you for your good questions!
It's a boost converter. And as it's described, the maximum input current is 4A. The output current is 0~4A which is according to the law of conservation of energy that it changes with the output voltage.
Any unclear, please feel free to share with us.
Best regards,
ICStation Team
The data sheet says it has Maximum 4A Switching Current and I suppose it is in the output stage. So, could this mean the input current could be higher? And thus, you can max out your power by increasing the input current as long as it will not reach or go beyond the maximum ratings?
datasheet link:
https://www.pollin.de/productdownloads/D351434D.PD...
Please help me,you can give me skema diagram for make power supplay n buck regulator using this chip(XL6009)
These are cool units. But When you wind the variable poteniometer too high they seem to pop, and then only pass through the input voltage. Has any one else found this issue?
Better still does anyone know of to fix it, or are they toaseted?
I suggest you to replace the potentiometer. rest of the circuit remains ok.
I have a 7.4v li ion battery will I get 12v 1.5a from xl6009
You have not informed the AH capacity of your Battery. Any way the module is useful for currents less than 1Amp. If you exceed that limit,the module will become hot & some of the SMD components come off. In your case,though the module works, it may not last more than few seconds.
You can get but current is reduced
hi I amusong 12v 2a supply an I need 50v @ 180ma will I get from this.
Do you have an IP65 version of this model? We need to use it in an LED streetlight which operates on 32V 600mah. We will input24V DC into the driver. Is the output self adjusting or is there a preset function??
im using this chip in a home made battery bank with 18650 cells just to step up the 3.5 - 4.2 volts up from the cells to 5 volts but the output capacitor on the chip is getting really hot and im not sure why
More Comments
