Introduction: The Star of Glory Skateboard
a cool rectangular board
two semicircular planks
two supporting spindles,
four unique pulleys
two shafts.
Step 1:
First of all, we need a flattened semicircular
tube, which is cut with a hollow semicircular tube to get a smooth arc bottom plate.
Step 2:
And turn it upside down.
Step 3:
After that we can install the wheels to it, so make a base first.
Step 4:
Install it on the finished floor
Step 5:
And fixed it with screws.
Step 6:
Then we install the bracket of the skateboard wheel (made of two tripyramid splits).
Step 7:
Then we continued to install fixtures and reinforce the wheels.
As a result, the fixing frame of the wheel was installed
Step 8:
Then we can install the wheels.
Splice them together
Step 9:
Then you can add some decoration, such as pentagram, ring, can have a better effect.
Step 10:
After that, we will install the bottom plate copy, and adjust the splicing, get the complete skateboard bottom plate.
Step 11:
Next, we'll put the fabricated wheels on.
And make some trimming of it to achieve more realistic effects (such as bracket or reduction).
Step 12:
After that we have to make the skateboard complete and make the skateboard more perfect. so we need a semicircle column to lower the height to match the previous bottom plate.
Step 13:
Then use a hollow cuboid to cut it in a similar way to the first step.
Step 14:
Then it can be connected to the previous floor and match. So splice it up and add some pattern embellishment. Such a skateboard will come to fruition.
