Introduction: The Perfect Cola-cuppa
everyone has ended up with a lot of coke-cans at some point. maybe it was a party, or some other celebration- it's always such a pity to throw away that amount of aluminum! so why waste them? here's a great way to reuse your old coke or sprite cans!
Step 1: Get 2 Cans
for one cup, you'll need:
2 cleaned and dried coke cans
some good scissors
superglue(I used loctite superglue)
a tin opener
Step 2: Take Off One Face
clamp the tin opener on the face with the lid thing, and take off the face as you would with a normal tin. you'll now have a cup. however, we want a mug, so we'll have to repeat this step with the other mug. put one of the cans to the side for later.
Step 3: Take Off the Other Side
take off the other side of the can in front of you in a similar fashion. now, you should have one coke cup, and one coke tube.
Step 4: Imma Makin Mah Handel
cut along the coke can (this will get a little tricky), trying to make a line that's as straight as possible. once you have opened the tube, cut along the rims to make a sheet of aluminium.
Step 5:
cut a 1 centimetre wide strip lengthways on the sheet of metal to form your handle. then, taking great care not to turn yourself into a human teacup, glue one end of the strip to the bottom of the can. glue the top bit to the top to form a handle.
Step 6: Wonder Why This Counts As a Step
SO, you are done! now, do the next obvious thing, and pour yourself some milk- DO NOT PUT ANY REALLY HOT BEVERAGES IN YOUR COLA-CUP. some warm milk might be fine, but actually putting any tea could burn you because of the metal's high heat conductivity; i haven't tested it yet though. you are done now! congratulations; you haven't just made an eco-friendly mug, you've also given yourself an excellent reason to drink canned drinks!
oh, yeah: i am not affiliated in any way with coca cola. use sprite cans, beer cans, pesi cans, anything really. i just used coke cans because they were the ones i could find. i later made a half-size coffee cup with a sprite can!
