Introduction: GoPro Pole Mount/GoPole
About: Just a guy who loves to make stuff. Please comment and follow for more.
1. The small piece of the side mount (as shown in picture)
2. Length of PVC Pipe (mine is 40cm)
3. Stainless steel nut and bolt (so it doesn't rust)
4. Rope of your choice
5. Rubber bike or scooter grip preferably with butt cap (I have an ODI Long Neck Grip off my bike)
Step 1: The Top (where the GoPro Will Be Mounted)
Take the smallest mount off the side mount of your gopro. (I'm talking about the extension bit with the smaller thumb screws)
Cut your PVC Pipe to desired length
Make sure the bottom of the mount fits very snugly into the pipe. If it does not fit perfectly (like mine) use another bit of pipe that will make it a tighter fit (I used reticulation pipe I found in the shed)
Once the bottom of the mount is in, drill a hole through the pipe and the hole in the GoPro mount, making sure it is large enough for your nut and bolt
Thread nut and bolt through the hole and do not do it up too tightly yet as you will need to remove it later.
Step 2: The Pipe
The pipe or middle is pretty straight forward
I sanded the edges off to make it smooth
I wrapped the middle with electrical tape at the very end for looks only, making sure not to cover the nut and bolt
Step 3: The Handle
The handle will need to be and very good fit on the pipe as it will otherwise come off and I don't know about you but I don't fancy holding a piece of PVC Pipe underwater
Before putting the grip on you will need to thread the string/rope through the pipe (this will require you taking the top off) and make a wrist strap (as shown in picture) leave about 7cm of string through the top of your pole.
Push the grip onto the pipe with out the Burt cap on
Once on put the butt cap on and make sure the wrist strap is not inside the pole
Step 4: Finished Product
With the left over string at the top you should probably wrap it around your GoPro for extra security.
You will also have to use the longer thumb screw as the shorter one did not for for me
Once assembled you now have your very own GoPole and have just save yourself $30!
I hope my idea has helped you
Please follow for more DIY GoPro and other things.
Step 5: Another Picture of the Top
Step 6: Another Picture of the Top
