Introduction: Tinkercad Coffee House
About: Hello! I do craft.
Hello!
This is my first tinkercad instructable and i found the experience very fun!
Step 1:
First, Make a base. This will be the place where all of the objects will sit.
Step 2:
Next, Make a building. I used a lot of glass in this building becase i wanted the the cafe to have a modern feel.
Step 3:
Time to furnish! I experimented with a lot of shapes to make this interior and also used some models from the tinkercad library.
Step 4:
Now for the sign. Make a rectangle and using the text feature, create some 3D text. Push the text into the rectangle and you have a sign. Attach it to the cafe.
Step 5:
For the exterior, Make some small grey walls around the edge of the structure. I added some built-in plant beds to the front. I also added some tree trunks and shrubs
Step 6:
For the trees themselves i used the light blue 3D star on the basic shapes menu. Strech it upwards and duplicate it, each time pulling the duplicates higher and rotating them. I ended up with the result you see in the picture above. Now, colour it green
Step 7:
Put the tree part we just made on top of the trunks. I had multiple trunks so i duplicated the tree part and changed the colour very slighly for each tree.
Step 8:
Add an outdoor seating area if you have space for one. I used the same chair and table design as i used inside the cafe.
Step 9:
And it is finished!
Thank you for reading this instructable
Check out my website!
https://moltcraftinstructa.wixsite.com/moltcraft
Thanks again!
