Introduction: Tiny Screwdriver
Ever needed a mini screwdriver?
No? Me either! But It was fun to make!
If you are intrigued, read on!
Step 1: Materials
What you will need
- Wooden dowel- your choice of size
- Sandpaper
- 18 Gauge wire
- Hammer
- Anvil -or- as I use, a mallet
- Drill with small bit
- Hot Glue gun
- Saw
- Common sense
Step 2: WoodWorking
First, Take your dowel and cut off about 1/2 inch off of the end.
Then sand the tops until they are smooth.
Sand the sides so it is still a circle but thinner.
Step 3: Almost Done
Now, cut the wire size to your liking.
Make sure there's room for the drilled part.
Now drill a hole, almost all the way through.
Then hot glue it into the hole.
Flatten one side of the wire
Step 4: Done!!
Now, use that sucker somehow!
Paint if wanted
Paint if wanted
