Introduction: Touchless Door Opener
About: Bringing Fiction to Reality.
This is a simple project to teach basic usage of Ultrasonic sensor with Servo motor to kids. The project is simple in terms of code, circuit & implementation.
Step 1: Material Required
  • Arduino Nano/Uno/Mini
  • SG-90 Servo motor
  • HC-SR04 Ultrasonic sensor
  • Jumper Cables
Step 2: Making the Connections
There are only a few connections to be made, follow the steps below:
  • Attach the Arduino board to a breadboard.
  • Connect 5v & GND to the side power rails of the breadboard.
  • Connect the VCC & GND of Servo motor & Ultrasonic sensor to the power rails.
  • Connect the Orange wire(Signal) of the Servo motor to pin 9 of Arduino.
  • Connect the Trigger pin of the Ultrasonic sensor to pin 10 of Arduino.
  • Connect the Echo pin of the Ultrasonic sensor to pin 11 of Arduino.
Step 3: Let's Code
Explanation: This code uses the simple Servo library.
  • Four variables were declared initially.
  • In the setup part, the Servo pin is declared as 9. Trigger pin is declared as output & Echo pin is declared as input.
  • In the Loop section, a function named Ultra was called & then the servo was made to rotate for 0 degrees.
  • If Case checks the presence of the hand in front of ultrasonic sensor & hence rotate the servo to 90 degrees.
