Introduction: Transparent Alligator Clips
Sometimes we just need a beautiful tools for aesthetic reason. Most of alligator clips have very bold color wire (usually red and black) with silver clips. I made this copper color alligator clips because the bold color wires distracted to show my work. This transparent clip is very easy to make and you can use various way for your projects.
Step 1: Materials and Tools
- Tools
Long nose (For cutting wire. you can use any cutting tools e.g. nipper)
Wire stripper
- Materials
Solid Copper Alligator Clips
Speaker wire
Masking tape
Urethane modified acrylic coating spray
Step 2: Split the Speaker Wire
Most of speaker wire is made of two different color wire. Split the wire and divide colors. I bought two different colors of speaker wire, blue and red. Cut those wire around 11 inch.
Step 3: Cut the Wire and Strip End Of
Cut the wire around 11 inch (any length you need)
Strip the wire both ends around 1.5 inch. (You need to peel off more than 1 inch)
Step 4: Tie Up
Put wire into the small hole on the copper clip. Turn around clips and put the wire back to the hole. If the wire is too loosen, you can trim some of it. (It should be a tight)
Step 5: Tighten Up Clips
You can find little teeth end of the each clip. Tighten up those teeth until the clip fixed with wire.
Step 6: Taping
Taping the clips front and inside with masking tape.
Step 7: Coating
Spray transparent acrylic paint for little insulation and protection
Step 8: Finish ;)
Now you have beautiful transparent alligator clips ;)
