Introduction: Trick-or-Treat Glowing Paper Bag
The concept for the Trick-or-Treat Glowing Bag emerged from a desire to infuse the age-old Halloween tradition with a futuristic twist. The ideation process involved brainstorming creative ways to make trick-or-treating not just about collecting candy, but also about making a memorable and captivating impression.
This innovative project combines the timeless tradition of trick-or-treating with the futuristic appeal of 3D printing and LED technology. It's the perfect way to stand out and captivate the imagination of trick-or-treaters, young and old, making you the center of attention during this thrilling night of costumes and candy.
THIS Trick-or-Treat Glowing Bag IS A PROP FOR HALLOWEEN THAT GOES ALONG WITH COSTUME.
- Paper Bag
- 5V LED Strip Light
- 3D Printed Halloween Glowable Pumpkin Badges
- Powerbank with a 5V output
- Scissors
- Transparent tape
- paper rope
- Glue gun
Step 1: Design Halloween Badges
- I use Fusion360 software to design your Halloween-themed badges. Consider pumpkins, bats, ghosts, or any spooky design.
- 3D print the badges using a 3D printer. Ensure they have a flat back to attach them to the bag later.
- I Import images downloaded from the Internet and trace images using Sketch.
- After making a sketch, use Extrude 3mm to make a 3D Badge.
- I attached My DXF file for anyone who wants to make a custom badge with custom height.
Step 2: 3D Print Halloween Badge
- Once your designs are ready, pay special attention to scaling them appropriately to ensure they fit well on your paper bag.
- transfer your 3D designs to your 3D printer.
- I use Glowable PLA material for 3D printing these badges.
- Watch as your intricate designs come to life, layer by layer, with the 3D printer meticulously crafting each badge. This step embodies the fusion of art and technology, making your Halloween creations truly futuristic and unique.
- Import STL file in CURA slicer to make 3D printed parts.
Use the below parameter for good 3D printing.
- Layer height: 0.2 mm
- Wall: 2
- Top / Bottom : 3
- Infill: 25 %
- Material: PLA White
- Speed: 40 mm / s
- Support: no
- Build Plate Adhesion: Brim
Step 3: Prepare the LED Strip Light
- Measure your paper bag's dimensions, ensuring a snug fit for your LED strip.
- Wrap LED strip around the bag and stick it with transparent tape at some intervals.
- To assess the LED strip's functionality and illuminate your Halloween spirit, connect it to a 5V power source such as a power bank. Observe the mesmerizing play of light, choosing your preferred lighting effects or color schemes to suit your spooky style.
Step 4: Decorate the Bag With Badges
- Let your artistic instincts flow as you decide where and how to adorn your paper bag with the 3D-printed Halloween badges. You have the creative freedom to arrange them in an artful pattern or place them in a more whimsical, random fashion.
- Bond the flat backs of your 3D-printed badges to the paper bag's surface using a glue gun, ensuring they form a seamless connection. The badges' captivating designs coupled with the bag's transformation will create a truly avant-garde Halloween accessory.
Step 5: Wiring the LED Strip to the Powerbank
- Gently position the power bank within the bag, ensuring it's discreetly tucked away yet accessible.
- Methodically route the cable from the LED strip to the power bank, ensuring it doesn't interfere with the LED lights. Use small strips of tape as needed to securely fasten the cable in place, ensuring that it maintains a tidy and streamlined appearance.
Step 6: Add Paper Made Rope
Make holes side by side on top of the bag.
sew paper rope inside the hole as seen in images.
Step 7: Final Touches
- Verify that all elements within the bag are safely secured, and no loose wires or connections are present, ensuring the utmost safety and durability of your creation.
- Congratulations, your Trick-or-Treat Glowing Bag is now ready to shine as a beacon of Halloween creativity! This fusion of technology, craftsmanship, and artistry will set you apart as the futuristic and avant-garde trick-or-treater, drawing admiration and awe on this haunting night. Enjoy your Halloween adventure!
