Introduction: Turtle Planter Pot Bowl
A pot for your plant in the shape of a turtle!
Fusion 360
Step 1:
Click Create New Sketch
Step 2:
Use the line tool to create an octagon. The four long sides should be 12 mm long. They should all be 12 mm away from the center. Then connect the lines to form the smaller lines.
Step 3:
Then make a circle centered at the center with a diameter of 19 mm. Then elevate it 15 mm.
Step 4:
Next, use the loft tool. Select both the octagon and the circle you made.
Step 5:
Then make a sketch of a circle with a diameter of 4.5 mm. Now you can extrude it 18 mm.
Step 6:
Now, create another circle with a diameter of 7.5 mm. Extrude that circle toward the turtle 4.5 mm and again in the other direction 2 mm.
Step 7:
Press the f key to fillet. Fillet the front side of the turtle's head 3 mm and the backside 2 mm.
Step 8:
Make a circle with a diameter of 4 mm in the middle of each of the smaller sides of the octagon. Then, extrude them 2 mm toward the top of the turtle. After that, fillet the upper edge of the cylinders 2 mm.
Step 9:
Now create a rectangle that covers the bottom of the turtle that goes below the x-axis. Extrude the rectangle -20 mm so your turtle can sit flat on a surface.
Step 10:
Make a circle with a diameter of 18 mm and extrude it -14 mm so there's a space for your plant to go.
Step 11:
Click "a" to choose a material for your turtle. After filleting other lines to make your turtle look nicer, you can render it.
