Introduction: Two Shelves to Put on the Wall.
These two shelves are to give your extra space or just to make your room look better, or cleaner. Also, you can paint them or spray paint them any color you want, you can make it space themed to make it look better.
A board
8 screws
Saw
Something to draw straight lines
Tape measure
A Pencil or Pen.
(Optional Paint or Spray paint).
Step 1: Cut a Board Into Two Pieces.
By using a saw cut a board into two pieces, and then you got two shelves. Cut one piece of your wood into 23' and 3/4" and the other piece of any wood that is smooth and easy to drill into and make them 25' and 3/4" so that one is bigger than the other and it will be by design.
Step 2: Draw Two Triangles at a 45 Degree Angle and a Straight Line Down.
Your going to draw two triangles at a 45 degree angle and then a straight line down to cut the two triangles in half, and that will make the hooks for one of the shelves and then do the same thing on the other shelf.
Step 3: Grab a Drill, a Bit, and 8 Screws.
Your going to grab a drill, a bit, 8 screws, then your going to drill 4 of the screws into the top of the shelf, then four more into the other shelf to create the hooks.
Step 4: (Optional Step, Paint Your Two Shelves Any Color).
If you want you can paint or spray paint your two shelves any color you would like it to be again this is optional you don't need to do it.
