Introduction: URJAA: THE ENERGY SAVING DEVICE
Do you often forget to turn off the lights when you leave your room?
If yes, then this device is just the thing for you to create and start saving energy.
Here is the youtube link of the device in action:
https://youtu.be/bIMr5IV9O_Y
Step 1: GATHER THE MATERIALS
This device makes use of :
1) 2 X Infrared Sensor
2) Arduino UNO Board
3) Breadboard
4) a Relay Module
5) 3 LEDs
6) a DC motor and a propeller (to represent a fan)
7) 3 X 1k resistors
8) Breadboard Power Supply (to provide power for motor)
Step 2: HOW THE DEVICE WORKS??
Whenever the sensors are triggered, a variable in the arduino code named person is increased or decreased by one depending on the order in which the sensors are triggered. The arduino does not switch off the appliances until the value of the variable becomes 0.
Step 3: WIRE UP THE ELECTRONICS!!
Both the infrared sensors are powered from the 5v pin of the arduino.
5v of Arduino---->Vcc of both sensors
GND of Arduino-----> GND of both sensors
pin 8 of Arduino----> OUT of infrared 1
pin 7 of Arduino----> OUT of infrared 2
The positive terminal of LEDs are connected to pins 2, 3, 4 of arduino with a 1k resistor and the negative terminal is connected to ground.
Vcc of Relay module-----> 5v pin of Arduino
GND of Relay module-----> GND of Arduino
IN2 pin of Rekay Module-----> pin 12 of Arduino
5v pin of the Breadboard Power Supply is connected to COM on relay and the GND pin is connected to the motor and the other terminal of motor is connected to NO(Normally Open) on the Relay.
NOTE: The Breadboard Power Supply is used to provide power to the motor and relay is used for switching a purpose. A NPN transistor can be used in place of the relay as switch. But the relay module will be required to implement the device at the home.
NOTE: Carefully set the range of the infrared sensors using the potentionometer and place sensors at different heights to prevent them from interfering in each other's path and to allow the creation of a time gap between the triggering of each sensor.
