Introduction: USB 10mm LED Lamp
The USB 10 mm LED lamp was built with a USB cable, a 10mm LED, a mini round PCB, and a resistor of 43 Ohm.
Step 1: List of Materials
1 USB Cable
1 Round mini PCB
1 10 mm Clear LED
1 Resistor of 43 Ohm
1 2" Heat Shrink tubing
Step 2: Schematic Diagram
Follow the diagram for completing your project successfully.
Step 3: Preparing the USB Cable
For preparing the USB cable, you should peel it and then removing the rest the wires by leaving the red and black one only.
Step 4: Place the Heat Shrink Tubing
Placing the heat shrink tubing, you can be sure that it won't be forgot of being used in the project.
Step 5: Insert the 10 Mm LED
After inserting the 10 mm LED, you should solder its pins on the round PCB.
Step 6: Soldering the Resistor of 43 Ohm
Solder the resistor of 43 Ohm.
Step 7: Assembling the Project
For assembling the project, you can use extra heat shrink tubing for adjusting better the connections.
Step 8: Completing the Project
For completing the project, slide the heat shrink tubing and heat it for adjusting it.
Step 9: Final Result
The final result is literally a flexible lamp that can be used in a laptop or USB charger.
Step 10: Using the Project
You can use the project with a laptop or USB charger.
