Introduction: Ultimate Altoid Survival Kit!
Okay, there has been a lot of hype about altoid tin survival kits. I've seen kits that were well thought out and practicable, and kits that were terrible and idiotic. But, after much work and exhaustion, I have found the ultimate altoid tin survival kit. Made in a Altoids mini tin, so it will fit anywhere, this kit has all you need to brave the wilderness, or survive the hot streets of some big city. Unveiling, the..... (drumroll please) .....
ULTIMATE ALTOID SURVIVAL KIT!
Step 1: What You Need
It's simple, you need Altoid Mini's, empty.
And...
Gummi bears.
And...
Gummi bears.
Step 2: Method 1: Ram and Cram
The first method I tried, was ramming and cramming. To use this method, take a handful of gummi bears, and ram as many as you can into the altoid tin. Typically you can fit around 9 into the tin without it popping back open when you close it.
But, this method is an inneficient use of space, so after much difficult research, I came up with method #2.
Step 3: Method 2: Tight Packing
With this method, you can easily fit in 11-12 gummi bears.
Step:1 Place 5 bears in side by side in the tin.
Step 2: Place 5 more above them.
Step 3: Carefully squeeze one or two beside those in there.
Step 4: Make a Lot
These kits are so important, you need to make many of them and distribute them to your friends and family.
Step 5: Disclaimer
As awesome as this kit is, you might not want to rely upon it during an actual disaster. instead, you should also carry around, a machete, a rifle, a pistol, and a bugout bag full of important supplies.
Once again, this kit is not meant for major emergencies, and I can claim no responsibilty for your zombiefication should you rely on it.
