Introduction: Up-cycled Musical Insturment: Rattle Drum
Musical instrument I chose to make is rattle drum. I chose this because it is easy to make and
you can use recycled materials to make it. Rattle drum is simple design that I decorated it more extensively.
Step 1: List of Materials
1) any circle shape with height of 1 inch\and hard
2)goggles or balloons
3)beads
4)duck tape
5)paper towel roll or make it from paper
6)scissor
7)hot glue gun
8)Construction paper
9)string or yarn
Step 2: Step 1
First cover your both open side of the circle with your goggles or balloon. Make sure to pull your goggles while you taping it. If you don’t pull it hard enough it will not make good sound
Step 3: Step 2
If your paper towel roll is big cut it in half
Step 4: Step 3
Tape your two sides of paper towel roll to make it like like before with smaller diameter.
Step 5: Step 4
Cover your paper towel roll with construction paper of your choice
Step 6: Step 5
Attach your handle to your circle shape
Step 7: Step 6
Cut out some flower out of construction paper to decorate the handle
Step 8: Step 7
Glue your flowers to the handle
Step 9: Step 8
Make little whole in construction paper that cover cside of circle and attach your bead to your string and glued to your paper. Cover side of circle with construction paper
Step 10: Step 9
Cover the side with duct tape of your choice and you are finish
