Introduction: Using a Smoothing Iron
Smoothing out your hair isn't rocket science but here's a quick tip on achieving that sleek straight hair.
Step 1: What You'll Need
The basics:
1. A smoothing iron
2. A comb
Step 2: Sectioning
My model has short bob so it's quite simple to smooth out. The key to sectioning your hair is first pick your part. After you chosen that the rest is simple. Tie up you hair so you start smoothing from the bottom upward. If you have thin hair 2-3 sections around your head will do, if it's thick I would do 3-4.
Step 3: Smoothing
Now to begin smoothing.
Two key points to remember:
1. The smaller the sections the better the results.
2. Using your comb is very important it helps provide tension and separation so your smoothing iron gets every little kink in your hair.
Step 4: Enjoy
You can style with your fav products and if you get tiny flyaways at the top of your hair I would recommend using a lite styling gel, mousse, or hairspray depending on your preference. Just remember less is more so you can maintain movement in your sleek straight hair
