Introduction: Vernier Battery Saver MK2
About: Woodsman and field tutor on a week day. Life long inventor, designer, engineer for the rest of the time. From items that make life easier to items with no reason to be....other than the idea popped into my hea…
I made a battery saver for one of my vernier calipers using an AAA battery
https://www.instructables.com/preview/E2VL1TBJGGTD...
It works perfectly but having found a slide switch that was smaller than the one I used before and, as I had yet another battery eating vernier needing modification, I thought I would redesign the whole thing :). I decided to stick with the standard battery as it lasts ok on a vernier that doesn't drain it when switched off.
No disassembly of the caliper is required to do this mod, just removal of covers.
Step 1: Parts and Tools
Not many parts or tools required for this build:
Parts
  • Vernier caliper with battery
  • 6mm perspex
  • 1mm brass
  • 3 M3 Dia x 4 csnk screws
  • Small offcuts of .5mm brass for contacts
  • 50mm of thin insulated wire
  • JB weld adhesive
Tools
  • power drill (pistol or bench) & drill bits
  • hand files
  • soldering iron and solder
  • Needle drill chuck
  • M3 tap
Step 2: Fitting the Switch
The switch fits in the recess where the battery usually sits, make room for it by carefully cutting out the plastic at the end to the width of the switch.
At this point confirm which terminal is attached to the frame of the vernier, in this case it is the positive so the switch will attach to the negative. Carefully bend and cut off the sprung parts of the battery contacts and tin what is left of the negative (the square one in the middle) .
Bend the centre and one end contact of the switch at 90 degrees, join them together by soldering a piece of tinned wire across them. solder a piece of thin insulated wire to the third terminal.
Now hold the switch in place and solder the joined contacts to the negative pad inside the battery compartment.
Take off the little side cover for ease of access, and using a drill just over the size of the piece of wire enlarge the existing hole on the corner of the battery holder, thread the wire through and replace the covers.
Step 3: Battery Holder
The 6mm perspex was cut to the width of the metal backplate of the vernier, the length is unimportant it just needs to have room for fixings and the battery. The cover was cut to the same size from 1mm brass.
Step 4: Attach the Battery Holder
Remove the aluminium foil label from the back of the vernier and clean off the glue, I scraped it off with a sharp chisel.
The holder is attached to the vernier with JB weld, make sure not to let it spill into the battery holder hole as this will cause problems with contact later. Make sure you pass the wire through the angled hole before pressing the parts together. Leave for 24 hrs to harden off.
Step 5: Connect It Up
I cut a couple of small pieces of thin brass one of which goes under the battery, the other one fits the part drilled hole, I gave it a thick blob of solder before connecting the wire as I wanted to be sure it stood proud of the perspex, I tickled it up with a flat file to get it just above the surface so that it would make good contact with the back cover.
Step 6: Cover on and Test!
All that remained was to screw the back cover on and test.
My first fixed vernier sits on the surface plate in the workshop, this one sits beside me at the computer both are always ready to use every time I need them.
