Introduction: Volume for Climbing
Volumes are a way to add variation to a flat wall, the are great for setting more interesting and thought provoking routes.
3/4 in ply wood
2 by 4 scrap
drill
drill press
belt sander
circular saw
compund miter
finish nailer
contruction adhesive or wood glue
bondo
polyester resin
70 grit aluminim oxide
fender washer
sand paper
a few paint brushes
brass brush
Step 1: Design
you need a very acurate design for your volume becasue a few degrees of error can drasticaly reduce the quality of the final product.
Step 2: Draw the Plans Out on Wood.
Ft might be helpful to use an angle finder. If the edges of the wood are straight you can draw off of them as long as only acute angels go against the edge.
Step 3: Cut Out the Wood
Cut out all of the sides exept for the top. Its easier to trace the top since its simple and thta leaves a little bit of room for error.
Step 4: Glue the Pices Together
Glue and nail the three of the pieces together to for a partial box.
Step 5: Add Braces
Add braces to the corners with glue and nails. I just used scrap ply wood. if possible put the nails in from the exterior so the dont come through.
Step 6: Glue
Glue and nail the fourth face on.
Step 7: Brace and Trace
Add braces to the corners and trace out the shape of the top face.
Step 8:
Glue and nail the top face on.
Step 9: Cut the 2 by 4
cut out a 2 by four to fit inside the volume and glue it down.
Step 10: Hammer
Hammer down the 2 by 4 to make sure its in all the way.
Step 11: Secure the 2 by 4
Nail the 2 by 4 from the sides and top to secure it.
Step 12: Screw It Down
Use finish screws to add strength to the 2*4. I used 8 screws. all of the cimbers weight will be on the 2*4 so make sure its strong.
Step 13: Sand
snad down all of the edges and rough spots. Make sure the volume is the shape you want.
Step 14: Bondo
Use bondo to fill cracks, holes and imperfections.
Step 15: Sand
sand off the bondo. you may need anouthe layr of bondo to fill everything I usually repeat the process 2-3 times.
Step 16: Drill
Use the drill press to drill 2 holes. the first should be the size of you washer and go through the plywood. the second should be a little bigger than 3/8 and go all the way through.
Step 17: Drill
Drill holes on the side to acomidate for a screw. You will also need to drill a bigger hole for the head.(not pictured)
Step 18: Insert Washers
Push washers into the screw holes with a punch.
Step 19: Texture
Coat volume in polyester resin, then cover the volume in aluminum oxide. you cant add too much exxes will just fall off. Allow the texture to dry then repeat for a second coat. Here is a good video on how to do it: https://youtu.be/65PFcQFxGFw
Step 20: Brush
After allowing texture to cure use a brass brush to remove loose texture.
