Introduction: W806 Microcontroller Code & Projects
This is instructions for Code and Projects for the W806 Microcontroller.
You can also check / addto the Blogs / Forum at the bottom.
My code is in Github :
https://github.com/jlsilicon/w806
Base Code & Setup Directions is from :
https://github.com/IOsetting/wm-sdk-w806
Install Code :
https://occ.t-head.cn/community/download - login vw42
Src code & Pdf docs :
http://82.157.145.101/download/toolkits/winnermicro/w806/
Reference Videos:
W806 MCU - First look :
https://www.youtube.com/watch?v=ylTpL9aVIAc
$2 Dev Board - What's The Catch? W806 Microcontroller Review :
https://www.youtube.com/watch?v=ehy5F7rlO7c
W806 MCU compiler tools and SDK setup :
https://www.youtube.com/watch?v=TNzzYpMNTlA
Supplier:
https://www.aliexpress.com/item/3256803436435640.html?spm=a2g0o.productlist.0.0.3ec939adbn5YFJ&algo_pvid=24a6e47e-c7a4-4292-b793-8e50fa33d96c&algo_exp_id=24a6e47e-c7a4-4292-b793-8e50fa33d96c-0&pdp_ext_f=%7B%22sku_id%22%3A%2212000026540748693%22%7D&pdp_npi=2%40dis%21USD%21%211.09%211.09%21%21%21%21%402103143616559908414096824e3609%2112000026540748693%21sea
Step 1: Setup the W806 MSYS Make Environment
Use Setup Directions from :
Install Code :
Additional code examples :
https://github.com/jlsilicon/w806/
Step 2: Write and Compile Code
Write the program to app/src.
Run the make.
Step 3: Flash to the W806 Board
- Plugin the W806 via usb cable to the pc.
- run ' make config ' -to find the serial port.
- run ' make flash ' - to flash to the board
Step 4: Test and Run the Code !
Click the Reset button - and let the code run !
