Introduction: WLT 1.0 (line Tracer)
Hi!
This is my first line tracer robot.I made it about 1 or 2 years ago.
Step 1: How Does It Work?
The black color doesn't reflect the light but white does.The line is black on white background.When the line is straight the both sensors are above the white background and it reflects the light from the LED to the photo-transistor.In this case the both motors are turning.But when the robot is on the turn one of the sensors is above the black line ,the light is not reflected and the motor on this side stops.When the one motor is stopped and the other is turning ,the robot goes to the side of the stopped motor.
Step 2: Materials
What you'll need:
Materials:
Materials:
- CD/DVD disc
- Wires
- Power Switch
- Motor Driver L293D
- Battery Hold
- Batteries
- Resistors
- LED
- Photo-transistors
- Motors
- Bolt and nut
- Scissors
- Pliers
- Knife
- Ruler
- Pen
- Glue
Step 3: Electronics
Step 4: Sensors
The sensors are made from photo-transistor and LED and also two resistors 220R.
Step 5: Body
Cut one square or triangle or circle from the CD/DVD or don't cut anything if you wish :D
On the obverse of the CD there are the motor driver and some of the wires ,battery hold and the power switch. I drilled holes in the CD for the wires ,the power switch and the bolt.
In fact first I put the battery hold on the underside but after that I put 3 batteries and because there was no place for them I put them above everything.But I haven't photo of the final version.
The bolt with the LED on it is for 3rd leg or something like that.
Also the nut is glued to the body and the bolt gets into it.
Motors are on 90 degrees from each other.
Step 6: The Line
The line is black on white background. It could be made with black pen or black paint or anything.
This is my line.
This is my line.
