Introduction: WRT 307 - Instructions Project
Materials needed:
Two Photos:
https://pickinsplinters.com/2020/01/11/syracuses-o...
https://www.nunesmagician.com/2016/2/24/11101292/c...
Adobe Photoshop Subscription
Mac Computer
Step 1: Open Adobe Photoshop
Step 2: Select Create New
a. Under the drop down arrow select PIXELS
b. Enter 2600 for Width and 1625 for height
c. Name the piece and select CREATE
Step 3: Click File in the Task Bar
a. Select PLACE EMBEDDED
b. Select the image provided of the Carrier Dome
c. Crop to fill the background.
- Do this by holding the shift key and pull each corner to fit
d. Click the check in the task bar
Step 4: Select the TEXT TOOL From the Task Bar
a. Click where you would like to place the text
b. Type Buddy Boeheim #35
- Utilize options in the taskbar to change the color, size or type of font
Step 5: Click File
a. Select OPEN
b. Pick the file provided of the player
Step 6: In the Toolbar Select the OBJECT SELECTION TOOL
- If you cannot find it press and hold the bottom right corner of the QUICK SELECTION TOOL
Step 7: Draw a Circle Around the Object You Would Like to Select
Step 8: Change to the QUICK SELECTION TOOL
a. In the task bar select the brush with the +
- To change the size, select the white dot with a number under
Step 9: In the Bottom Right Corner Select “ADD a MASK”
Step 10: Press and Hold on the Image
a. Drag to the tab with the background
b. Place in the center of the background
Step 11: Select the Background in the Layers Panel
a. In the bottom right corner select the circle that is half black half white
b. Press the brightness/contrast option
c. With the brightness slider, make a brightness of -80
d. With the contrast slider, make the contrast 85
Step 12: Select the Player Layer
b. Press the vibrance option
c. With the vibrance slider, make a vibrance of +80
d. With the saturation slider, make a saturation of +30
