Introduction: Walking Jack O' Lantern
Ok this is a similar lantern to the others i have produced here except for the arms and legs . so here you go.....
Step 1: Surface Sweeps
Draw a spline long enough for an arm on the plane just about half way into the pumpkin.
Draw an elipse at each end point of the spline, making the one coming out of the pumpkin larger.
Then using surface loft and the spline as a center line create the outer surface of the arm.
You can do the same to create a curled type of hand look, check out the screen shot.
Using, features mirror,  mirror the arm as bodies to copy it over to the other side.
Step 2: Surface Sweeps Again
As like before with the arms use similar techniques to produce the two legs, see the screen shots.....
